NodJr
Mar 20, 2021Aspirant
EX6120 AC1200 isn't working properly
Afternoon all, Background I have had an engineer out several times to investigate the 'line' and ensure my internet is working. The line is now fine, bios reports are great and a new router fro...
NodJr
Mar 22, 2021Aspirant
Mar 23, 2021Guru - Experienced User
It doesn't look like you have any devices connected to the 5ghz band. 2.4ghz is slow and sensitive to interference.
Make sure to test over the 5ghz band
- NodJrApr 27, 2021Aspirant
Sorry for my delayed reply I have been working away from home this past month.
Ok so summary - the extender still does not provide any consistent internet and the speed test results are awful.
- All the lights are green
- Both 5Ghz and 2Ghz are available on WiFi
- Can we confirm the ‘NOW Broadband Hub Two’ works for 5Ghz?
- I have selected Router-to-Extender in 5GHz only and Extender-to-Device in 2.4GHz only (Router must support 5GHz band) – I am not seeing any improvement
Please can anyone suggest a guide how to fix this issues once and for all?
- plemansApr 28, 2021Guru - Experienced User
NodJr wrote:Please can anyone suggest a guide how to fix this issues once and for all?
If only it was that easy.
Is the EX6120 a new device? You can always go through support.
I'd also recommend trying it at someone else's home as well (if you have that option).
Reason I say that is I'm not trusting of ISP supplied gateways. They tend to be the cheapest device possible.
