waynewal
Jul 22, 2020Initiate
EX6120 cannot see its network on my computer using Apple Airport
HAve an Apple Airport with EX6120 extender. Tried WPS button on extender then pressing wps button on back of Airport router. No luck. Tried looking for the extender network and my computer isnt sho...
Jul 23, 2020Guru - Experienced User
If you tried setup using wps, try factory resetting and re-running setup using the installation wizard.
waynewal
Jul 23, 2020Initiate
Thanks very much !
I used my mobile device -iphone - beause the search for nearby wireless networks is not inhibited on that.
I did find it and am workign on the install. now, thanks for the reply!
