acsoup
Sep 30, 2020Aspirant
EX6120 cant access installation assistant video
just got a new router from Verizon and can not set up extender. No WPS button and cant get access to the Netgear Insstallation Assistant because the network,Netgear_Ext does not show up. Help me set ...
- Oct 01, 2020
Which verison router are you connecting to?
some of verizon's routers need the setting for self-organizing network to be disabled prior to setup.
Did you factory reset the extender? Push and hold reset for 7-15 seconds while its powered on. That should get you back to stock settings for setup.
Oct 01, 2020Guru - Experienced User
acsoup
Oct 02, 2020Aspirant
Thanks for your help
