EvJD
Sep 09, 2020Initiate
EX6120 Can't connect extender to my devices
Hi newly bought AC1200 Dual Band WiFi Range Extender (EX6120) through Amazon. Had good reviews. Followed the Quick Start guide to set up Extender Connedcted to Router no problem. (Router = techn...
Sep 09, 2020Guru - Experienced User
Did you set it up using wps? Technicolor seems to have issues with wps.
Try factory resetting the extender and reinstalling using the installation assistant.
