endorphin's avatar
endorphin
EX6120 connected, but no internet
My two EX6120 wif extenders stopped working after I changed router to ASUS RT-AC88U
AFter a factory reset and latest firware update . I can connect to the Extender, but No Internet
I checked PC ipconfig, it got default gateway 192.168.1.250. When I assign static IP and static gateway 192.168.1.1 everything works on PC. So, it looks like the extender assigns wrong default gateway to connected PC
And strange thing 2 of my extenders do not work...  is there is a way to fix it?
  • SOLVED
    In hope if it can help somebody one day, posting my answer
    The ASUS router RT-AC88U have weird feature "Airtime Fairness", set it to DISABLED
    It is on the Wireless>Professional settings section. Worked after that for me.  Router reboot no required.
    The feature purpose to increase router range, but caused problem to my extenders and wireless printer
1 Reply
  • SOLVED
