KasKelly
Jul 20, 2021Tutor
EX6120 connecting to a WiFi Antenna
I have a wirreless router in the house and need to get WiFi signal into the detached garage. Problem is our garage is - double wall steel w/ insulation in the middle. Nothing get through!! I pur...
Jul 20, 2021Guru - Experienced User
KasKelly wrote:. What am I doing wrong?
what you're doing wrong is trying to get a signal through steel. double walled at that.
Its one of the top blockers of wifi.
Options?
1. drill through it and run ethernet out to the garage
2. use powerline adapters to get out to the garage
3. use moca adapters (ethernet over coax)
You can keep trying at getting a signal through it but it isn't an issue of the devices but an issue of wifi doesn't broadcast through steel
- KasKellyJul 20, 2021Tutor
Correct - about trying to go through steel. That is why I got the WiFi antenna. It is mounted on the outside of the garage and the hardwire goes into the garage and plugged into the extender. The antenna is actually line in site of the wireless in the house. So it should have a very good signal.
- plemansJul 21, 2021Guru - Experienced User
so the Extender is in the garage with the antenna in the home? (going through the wall)
It'd mean there isn't any antenna's in the garage to broacast. If you hardwire a pc/laptop into the extender, does it work? It'd also let you check the connection back to the router.
- KasKellyJul 21, 2021Tutor
plemans Yes, the extender is in the garage w/ it's antennas on it still in tact. Then hard wired to the extender is the antenna that is outside (via a drilled hole in the walls). So there is an antenna (the extender) that is broadcasting the signal in the garage.
I checked all of the connectors and found an issue w/ one. Got that corrected. Now I do have all the lights on the extender green. Including the one saying connected to the router. I was able to get a signal to my phone via that signal. So I believe I have the problem solved. I do appreciate your assistance. It allowed me to rethink my process and arrive to a solution. Thanks for your time and consideration. Kas
