Johnsaunders44
Apr 06, 2019Aspirant
EX6120 constantly losing internet connection
I recently upgraded my firmware to 1.0.0.46 and my extender keeps losing internet connectivity. My smart thermostat and ring doorbell rely on the extender the most. The only solution to get back onlin...
Apr 07, 2019Guru - Experienced User
If the resetting doesn't work, try troubleshooting, and then if that doesn't work you can downgrade firmware.
Everything worked great prior to the update? Try the troubleshooting for extenders at the link provided. Maybe the firmware update changed what wifi channel you used and that one has interference. Or some other change caused a problem.
https://kb.netgear.com/25731/Troubleshooting-NETGEAR-WiFi-Range-Extenders
If that doesn't help at all you can downgrade your firmware. The link at the bottom will have the download link to get firmware. Where the current version is, there's a +view previous versions. This will have the older firmware. Follow the manual update procedure and use the older firmware. If at all possible do it over a hardwired connection. After the downgrade, reset the extender again. Then go through your setup.
Johnsaunders44
Apr 15, 2019Aspirant
Looks like the factory reset did the job. My extender hasn’t lost connection since
- Johnsaunders44Jul 05, 2019AspirantLooks like the issue is back again...very frustrating because my ring doorbell and thermostat are down every time the extender goes offline...may look to buy a new one tomorrow
