GerhardS
Jan 04, 2021Tutor
EX6120 Firmware Update
Using the EX6120 without any problems for a couple of years, but after a move I had to reinstall my network and did an update on the firmware as well. Done this update, the unit is working properly i...
- Jan 04, 2021
when you're trying to access it are you using the mywifiext . net or the ip address?
Try logging into the speedport and finding the IP address for the extender and use that to connect to it.
Jan 04, 2021Guru - Experienced User
what modem/gateway did you connect it to?
GerhardS
Jan 04, 2021Tutor
A Speedport W 724V Typ C
- plemansJan 04, 2021Guru - Experienced User
- GerhardSJan 04, 2021Tutor
Just to ensure: the extender is working in my network, ie I can use as an AP but to access the unit themselves to check, modify etc as I did in the past via a web browser will not work.
understood.
But how are you trying to access it? Via mywifiext . net or using its ip address?
What error is it giving you?
