GerhardS
Jan 04, 2021Tutor
EX6120 Firmware Update
Using the EX6120 without any problems for a couple of years, but after a move I had to reinstall my network and did an update on the firmware as well. Done this update, the unit is working properly i...
- Jan 04, 2021
when you're trying to access it are you using the mywifiext . net or the ip address?
Try logging into the speedport and finding the IP address for the extender and use that to connect to it.
