TangiblePear
Apr 10, 2021Aspirant
EX6120 in Access Point mode - very slow Wifi , Why?
Hello, I bought a EX6120 a while ago to use as a WIFI booster, I decided against it. Now I have it setup as an access point connected to my wired network. My actual router is downstairs and t...
Apr 11, 2021Guru - Experienced User
Have you checked the cable the extender is plugged into to see if the extender is getting full speed?
TangiblePear
Apr 11, 2021Aspirant
Yes, I have connected this direct to my PC and it gets full speed.
- plemansApr 11, 2021Guru - Experienced User
what link speed is the phone showing? (thoughput tends to be roughly 55-65% of link speed)
- TangiblePearApr 11, 2021Aspirant
My phone shows connection link speed as 702 Mbps but a speed test only gets 50-65Mbps when connected to the EX6120.
The same phone shows 866Mbps link speed to my router and that gets a speed of 130-150Mbps.
The phone is not the issue, The actual link speed does not appear to be the issue, but for some reason the actual speed cannot go over 65Mbps on this.
have you tried other devices?
