ether123
Apr 18, 2021Aspirant
EX6120 Is not as fast as the wifi speed in the same room.
I recently purchased a Netgear EX6120 to have a wired ethernet to my PC with higher speeds. The wifi in my room is around 200-300Mbps, however, the wifi extender is only at 20-30 Mbps without eth...
charliebill100
Hi ether123 ,
I have an EX6120 – AC1200 Dual Band WiFi Range Extender for my room PC. I was facing the same kind of problem as you. On wifi I was getting speed even worst then you. Back then I was writing an article what is all purpose flour for my website it takes several mins to upload media on my website.
All I do is change my wifi channel from default to a specific range by analysing which channel is free in my surrounding. Try to change wifi channel may be its help.
Charlie
ether123
So, you changed the frequency?
I think that might be the solution fo rme, changine 2.4ghz to 5ghz.
Could you tell me how did you do that?
