dlwmacgregor
Dec 25, 2025Follower
EX6120 Network Names
I have 2 EX6120 Extenders. What would the extended network names be for both. I can see SSID_2GEXT and SSID_5GEXT but only one entry for each one. But I have 2 units. Should I not be see...
Jan 05, 2026Guru - Experienced User
You would on a wifi analyzer however having two will show the same on a mobile device like a phone or pad.
You could let the extenders connect and then select use same SSID name network for the output of each coming from the main host wifi router signal.
