Forget9630
Jan 23, 2020Aspirant
ex6120 No internet
Hello, I just bought ex6120. The smart router has been connected to the main router's wifi, but there is no network. The expander indicator is normal.
Jan 24, 2020Guru - Experienced User
1. What router are you connected to?
2. what firmware is on the extender?
If you set it up via wps, I'd factory reset the extender and try setting it up via the smart connection wizard. Sometimes the wps functions aren't the same between manufacturers.
the support site has a video of using the smart connect wizard as well as its in the manual.
Forget9630
Jan 24, 2020Aspirant
1. Connect the only router
2. The expander is the latest firmware
Expander wps cannot be used without response Mobile laptop wps available Resetting the expander is still the same
- plemansJan 25, 2020Guru - Experienced User
Forget9630 wrote:1. Connect the only router ------this didnt help at all. What router? model?
2. The expander is the latest firmware--------Which firmware is it? The latest isn't a number.
Expander wps cannot be used without response Mobile laptop wps available Resetting the expander is still the same------This doesn't make any sense. I'm not even sure what you're saying here. Punctuation and complete sentences help me understand what exactly is going on. If you're having issues with wps then try the setup via the smart installation wizard. There's a video on the support site that walks you through this.
- Forget9630Jan 26, 2020Aspirant
1.Router Askey RAC2V1K
2.Firmware version: V1.0.0.48_1.0.30
- plemansJan 27, 2020Guru - Experienced User
This is the community forum where members of the public try to help others out. We're not paid for it. You're not helping me to help you. I'm not going to fight to get answers from you.
If you want help, please go into more details.
