JenMolke
Aug 30, 2019Tutor
EX6120 not accepting WIFI password on any device so cannot continue set up
I am setting up my workplace with this wifi extender and it is connecting to the router but not accepting the correct WIFI password. Because of this I can't do any of the other troubleshooting option...
Aug 30, 2019Guru - Experienced User
So much in such a short statement without some key info.
What is your workplace using for a router?
Is this router managed by an IT department? Do they have to allow specific devices to connect? I'd be checking with them first before going further if you have an IT department.
If you don't, and its a consumer device, a model number would help.
- JenMolkeAug 30, 2019Tutor
Thank you so much for getting back to me. It's just a small business so no IT dept. We are using an XLN Fibre router. It connects absolutely fine to all other devices on the network when we are connecting directly to it.
