JenMolke
Aug 30, 2019Tutor
EX6120 not accepting WIFI password on any device so cannot continue set up
I am setting up my workplace with this wifi extender and it is connecting to the router but not accepting the correct WIFI password. Because of this I can't do any of the other troubleshooting option...
Aug 30, 2019Guru - Experienced User
The ex6120 has an ethernet port on the side.
You can plug into the extender via this port and navigate to mywifiext.net
This should allow you to log into the extender. You can check firmware from there, do updates, manually setup the extender, etc. The manual is great for walking you through some of these steps.
JenMolke
Aug 30, 2019Tutor
Ah I didn't think of that thanks. I'll try and get my hands on a ethernet cable and try it out. Thanks for your help I'll let you know if I manage to sort it!
