maffcoff
Apr 13, 2020Aspirant
EX6120 not working with dfs channels
Good Morning, I have a ex6120 WiFi extender that I am using as a WiFi bridge, not as a WiFi extender, I have disabled the WiFi capabilities. I am really pleased with the performance of it, getting ...
Apr 13, 2020Guru - Experienced User
what firmware version are you on?
do you have the region set properly for both router and extender?
maffcoff
I downloaded the latest firmware which I believe ends in 48.
My router is registered in the UK region. In the UK you can use the dfs channels if the router is set to automatic channel selection not manual. My router sets the WiFi channel to 104, but the ex6120 does not recognise that WiFi channel. It states that it cannot use the channel due to a radar issue. I am not sure how to check the ex6120 for its region.
- plemansApr 13, 2020Guru - Experienced User
My router is registered in the UK region. In the UK you can use the dfs channels if the router is set to automatic channel selection not manual. My router sets the WiFi channel to 104, but the ex6120 does not recognise that WiFi channel. It states that it cannot use the channel due to a radar issue. I am not sure how to check the ex6120 for its region.I'm not sure about the UK support for dfs in the EX6120. I seen in one of the firmware release notes for FCC dfs support (US dfs) and JP (japan) dfs but didn't see anything on UK.
