Richard001
Apr 16, 2021Aspirant
EX6120 Password Issues
Hi, My extender connects to the router and I have a green light, however when I try to connect my laptop, having tried 2no. of them, it says the WiFi Network Key is incorrect. Its is the same one us...
Apr 16, 2021Guru - Experienced User
What router are you connecting it to?
did you install the extender using WPS (push button) or using the installation assistant?
Richard001
Apr 24, 2021Aspirant
Hi, I sorted it thanks. Router was connected to extender via WPS, so I tried the same with the laptop to the extender and it worked.
Thanks
