RevEarl's avatar
RevEarl
EX6120 security update
Can't get Netgear to connect to this extender. It's been up and running for years, but when I try to do security update by several diff means, I can't get Netgear to acknowledge that it's there.
  • RevEarl's avatar
    RevEarl
    Dec 08, 2017
    router isn't Netgear, it's PACE.
    OK, figured out how to log onto router. discovered why extender was invisible - it had a diff IP Address. Thanks for your help. Pls, pls add instructions to process for extenders.
