RevEarl
Dec 03, 2017Aspirant
EX6120 security update
Can't get Netgear to connect to this extender. It's been up and running for years, but when I try to do security update by several diff means, I can't get Netgear to acknowledge that it's there.
- Dec 08, 2017
router isn't Netgear, it's PACE.
OK, figured out how to log onto router. discovered why extender was invisible - it had a diff IP Address. Thanks for your help. Pls, pls add instructions to process for extenders.
DarrenM
Dec 07, 2017Sr. NETGEAR Moderator
Are you able to log into your router and look at the attached devices and see if the extender is getting a new Ip address?
DarrenM
RevEarl
Dec 07, 2017Aspirant
how do i do that?
- DarrenMDec 08, 2017Sr. NETGEAR Moderator
depends on your router if its a netgear router you would go to 192.168.1.1 or 192.168.0.1 login with admin/password and then go to Advanced-Administration-Attached devices.
DarrenM
- RevEarlDec 08, 2017Aspirant
