RevEarl
Dec 03, 2017Aspirant
EX6120 security update
Can't get Netgear to connect to this extender. It's been up and running for years, but when I try to do security update by several diff means, I can't get Netgear to acknowledge that it's there.
- Dec 07, 2017
router isn't Netgear, it's PACE.
OK, figured out how to log onto router. discovered why extender was invisible - it had a diff IP Address. Thanks for your help. Pls, pls add instructions to process for extenders.
DarrenM
Dec 07, 2017Sr. NETGEAR Moderator
depends on your router if its a netgear router you would go to 192.168.1.1 or 192.168.0.1 login with admin/password and then go to Advanced-Administration-Attached devices.
DarrenM
RevEarl
Dec 07, 2017Aspirant
