helldoc88
Dec 26, 2024Aspirant
EX6120 stopped working after 6 months
EX6120 stopped working after 6 months. Red lights for both router and device. Updated firmware and reset the device but still not working.
helldoc88
Dec 28, 2024Aspirant
Actually I was mistaken. The Power light is not amber it is green. The Router and Device lights are now blank. This is after firmware update and reset.
Dec 30, 2024Guru - Experienced User
Sounds like you successfully reset it then. The device light comes on when you have something connected via wireless and the router light is for when its connected to a router. So you'll want to go back through setup.
