Googolplex
Jun 11, 2016Follower
EX6120 vs. EX6150
Hi. I am looking to buy one of the following Wifi-extenders. However I cannot find any differences between the two models: EX6120 EX6150 Except that one is bigger than the other one ofc....
- Jun 11, 2016
So the main differences are that the
6150 has a slightly more powerful CPU
With that CPU power it can now do Simultaneous dual band WiFi, which the 6120 cant
It also has a Gigabit (10/100/1000) ethernet port vs the 6120 having aa FastEthernet(10/100)
The 6150 also has an ability to switch to Access Point Mode (is done via physical switch)
The last bit is the 6150 has an extra Physical button of WPS button
hope that helps
mystichead
Jun 11, 2016Initiate
hope that helps
