bibol
Dec 12, 2018Tutor
EX6120 Wifi Extender CANNOT change its name
Hi,
In the IP ADRESS / NAME OF DEVICE : " ******* "
Whatever the new name I m trying to give the EX6120 Wifi Extender / saving.
The original extender name will still display in Browser when...
Dec 14, 2018Guru - Experienced User
Can you try "pinging" the extender using the name you set from a PC?
With Windows you can also use ping -a IP-address and Windows will attempt to resolve the name.
bibol
Dec 14, 2018Tutor
can ping, but cannot retreive any name....
- StephenBDec 15, 2018Guru - Experienced User
One aspect here is that Windows 10 has shifted from NetBios discovery to WS-Discovery (Web Services Dynamic Discovery). I don't know if the EX6120 supports WSD, but I am guessing not.
So this might be something you just need to live with.
- bibolDec 15, 2018Tutor
I tested it under Linux and it doesnt work better than with windo
Still, why can the router detect new assigned name for PC while it can not do the same for the Wifi Extender ?
- StephenBDec 16, 2018Guru - Experienced User
Windows 10 would be advertising it with a different discovery protocol?
