bibol
Dec 12, 2018Tutor
EX6120 Wifi Extender CANNOT change its name
Hi,
In the IP ADRESS / NAME OF DEVICE : " ******* "
Whatever the new name I m trying to give the EX6120 Wifi Extender / saving.
The original extender name will still display in Browser when...
schumaku
Dec 20, 2018Guru - Experienced User
Back to square one.
Completely independent from NetBIOS or WSdiscovery or whatever - the extenders don't announce any of these names, so there is no name resolution (based on the device itself).
The extenders do however offer Windows Connect Now (WCN) announcement. Here the custom name is used, e.g. on the EX3700 V1.0.0.76_1.0.49, the custom name is used, here e.g. EX3700-1.
What does not work: The custom extender hostname is not used as part of the BOOTP/DHCP request. Typical careless coding, limited QA testing, and ignorance (we reported this several times on Netgear Extender Beta tests!). Welcome to the consumer *****. Guess this is related to the fact that the names are stored on the Netgear routers, and can easily be edited 8-/
So, the name can be changed, it's just that the changed name is not systematically used.
bibol
Dec 20, 2018Tutor
Tks Schumaku,
for your info...as for the routers I m connecting this EX6120 to they are not Netgear Brands but rather TPLink.
I've also connected it to another TPL Model and they would all display EX6120 as the connected model device
(even after I'd try to change its name).
Therefore their is a way (???) that their DHCP list could figure the real device model name without any manual modification from me.
But as you say so, Netgear probably doesnt care much about making their "renaming" feature complete the job properly.
I wonder if all the other Neatgear Wifi extenders do suffer the same "device renaming" weakness... ?
...such as models of the Nighhawk line, any idea ?
tks
- schumakuDec 20, 2018Guru - Experienced User
Router is not not relevant...
No magic, they use the model name - hardcoded (insead of reading from the config) - for the dhcpd.
