Ronnie1630
Jan 21, 2021Aspirant
EX6120 wifi range extender
I’ve been told it’s possible to to connect a range extender to another range extender so that I can get wifi from bt home hub to an outside building. Can’t see anything in the manual or on netgear web...
Jan 21, 2021Guru - Experienced User
You can daisy chain extenders but they tend to have horrible performance.
Reason why is each hop drops performance 50%. It does this because extenders have to go router---->extender and then extender----->device. and it can't do both at once because it uses the same chip. So you loose 50% of your speed per hop.
so if you have a 2nd extender, its maximum speed is 25%. And thats if its got a good signal.
Easiest way to setup is using the installation assistant and not using wps.
So setup the first one to the router, then setup the 2nd one.
- Ronnie1630Jan 21, 2021AspirantThanks
It’s for a couple of wifi cctv cameras, about 30m from the house, clear line of site but an old brick garage at the destination end
