dobeman73
Apr 09, 2020Guide
EX6120 Will Not Connect to Internet on 5Ghz
I purchased an EX6120/AC1200 to extend my NightHawk R8000 router. The first one I got wouldn't connect to the internet at all. I spoke to Tech Support and after running through the same troubleshooti...
Jbaviello
Apr 09, 2020Initiate
Having the exact same issue. Tried 2 extenders with exact same results. My provider is Verizon FIOS with a 3100 router. Was going to try chaningimg the channel on the 5Ghz on the router. If that does not work going to try another brand.
dobeman73
Apr 10, 2020Guide
Good luck. I have tried all of the channels, and no dice. This just really makes zero sense. Particularly, when I'm using ALL Netgear gear. And they can't even get their top of the line equipment to work with each other?
Jbaviello wrote:Having the exact same issue. Tried 2 extenders with exact same results. My provider is Verizon FIOS with a 3100 router. Was going to try chaningimg the channel on the 5Ghz on the router. If that does not work going to try another brand.
