mvbapat's avatar
mvbapat
Follower
Oct 02, 2021
EX6120
I have purchased EX6120|AC1200 Dual Band WiFi Range Extender. After configuration as range extender I could connect to the extender. However the WPS light is seen as OFF, where as the manual says that if this LED is off it indicates that WiFi secutrity is not enabled.
Please help in how to enable the WiFi Security.
1 Reply
  • olympos1625's avatar
    olympos1625
    NETGEAR Employee Retired
    Hi mvbapat,
    Welcome to NETGEAR Community!
    Thank you for reaching out. We are sorry for not being able to get back to you immediately. May we know if you have security or a wireless password on your main router? Using a computer or any device currently connected to your extender, open a web browser and go to www.mywifiext.net and check the wireless settings if there's no password. You may also take a screenshot so we can review it.
    Please do not hesitate to let me know if you need further assistance.
    Oliver
    Community Team
