FrancoAgo
Oct 16, 2019Aspirant
EX6130 AC1200, I need to change the saved router's password
I've a wifi range extender AC1200 Model EX6130, i need to changhe the saved router's password, how i must go on? I'm sorry for my bad english
Oct 16, 2019Guru - Experienced User
The routers wifi password or the login to the gui?
If you need to change what ssid and password the extender is trying to connect to, connect to the extender either with an ethernet connection or the wifi. Then go to mywifi.ext and log into it. from there you can go through setup again to connect to the wireless.
- FrancoAgoOct 16, 2019Aspirant
The routers wifi password, but i don't need to change the ssid only the password, i just noted that i've misstyped the password for the 5 ghz
