FrancoAgo
Oct 16, 2019Aspirant
EX6130 AC1200, I need to change the saved router's password
I've a wifi range extender AC1200 Model EX6130, i need to changhe the saved router's password, how i must go on? I'm sorry for my bad english
FrancoAgo
The routers wifi password, but i don't need to change the ssid only the password, i just noted that i've misstyped the password for the 5 ghz
Oct 16, 2019Guru - Experienced User
should be able to hardwire in or connect via the 2.4ghz. From there you can login to the extender and change the wifi settings.
- FrancoAgoOct 16, 2019Aspirant
Yes I can login in mywifiext.net but i don't know as change the right setting
- plemansOct 16, 2019Guru - Experienced User
page 12 of the manual. just redo the "new extender setup". It'll let you go back through connection to the router and wifi settings.
- FrancoAgoOct 19, 2019Aspirant
thank you for your time, but i've not new extender setup button, i suppose because is not a new extender
