ArildTho
Aug 30, 2019Aspirant
EX6130 Choosing SSID
Hi. I just bought this wifi-extender. In the quick-guide it says: "Note: We recommend that you use a different network name (SSID) for your extender from the network name (SSID) that your router use...
- Aug 30, 2019
Hi again.
Thanks for a good useful answer. I'll read the article an deside if i'll configure my extender using different SSID.
Best regards form ArildTho
ArildTho
Hi again.
Aug 30, 2019Guru - Experienced User
If your current setup is working and you're not experiencing slow speeds/disconnects/other issues, I'd probably leave it as a single ssid. But if it changes or issues crop up, then I'd probably seperate them.
