DarknessFX
Mar 20, 2019Tutor
EX6130 Locked at Setup Wizard Form.
My EX6130 Wireless Extender receive an update recently, since then it's failing in many ways:
- New Extender Setup form fails and don't progress to NEXT page, whatever information I fill in it's ju...
- Mar 28, 2019
After the Factory Reset I was able to complete the Registration Form using Opera Browser. It disconnected twice while entering the "Search for Wireless Networks" page, but leaving the web page open and reconnecting to NETGEAR_EXT access point did work out and I was able to finish the setup.
As soon it got online it told me again a new firmware update was ready (the last firmware update got me into this problem), I took the time to annotate my current firmware version and what the new version features:==
Firmware Version: V1.0.0.24_1.0.14
...Error on registration setup form.
New Version V1.0.0.28_1.0.16
1. (1) Fixed security issues.
2. (2) Add new registration flow.
==I updated the firmware, I will wait for tomorrow when the extended network users will tell me if everything is back to normal.
Thanks FURRYe38 for your help and support here, I appreciated.
Mar 20, 2019Guru - Experienced User
Is the FW up to date?
What browser are you using to walk thru the setup? Try IE11, FF or Opera.
What is the mfr and model# of the host router?
DarknessFX
Mar 21, 2019Tutor
Yes, the problem started after the last FW update.
Opera and Chrome.
Netgear Nighthawk R8000 AC3200 with updated firmware.
- DarknessFXMar 21, 2019Tutor
I will try with Internet Explorer/Edge and see if it makes any difference .
- FURRYe38Mar 21, 2019Guru - Experienced User
Let us know. Might try a factory reset and clear out all browser caches, exit the browser and try.
- DarknessFXMar 28, 2019Tutor
With Internet Explorer, the browser return to SETUP NEW EXTENDER page but I noticied that the URL changed to this :
http://[IP]/%22);%20%20%20%20%20%20%20%20%20%20%20%20var%20errorCode%20=%20parseInt(retStr[0],%2010);%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20if%20(errorCode%20==%201)%20%7B%20%20%20%20%20%20%20%20%20%20%20%20%20%20$(%22I will try the Factory Reset later today.
