BillF100
Jun 15, 2021Follower
EX6150 AC1200 power light stays amber
My AC1200 no longer has a router link led, client link led, power led green, and WPS led.
The power LED stays amber. Is this unit toast?? Thank you
1 Reply
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
