windave's avatar
windave
EX6150 vs EX6150v2 - Difference?
Does anyone know what is the difference between the EX6150 and the EX6150v2 models?
Is it a hardware or firmware difference or both?
If it is a firmware difference, then can the EX6150v2 firmware run on EX6150 hardware?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello windave
    It would be both so you can not use the firmware from one on the other.
    DarrenM
