Retired_Member
Mar 31, 2019EX6150/AC1200 WiFi range extender - no internet
Hello everyone,
I've been using a Netgear EX6150 for years and it worked a charm all that time until the most recent firmware update. Since then, computer - a mac - tells me the device is conn...
Apr 01, 2019Guru - Experienced User
Try a factory reset and setup from scratch.
What is the distance between the EX and the main host router?
What is the mfr and model# of the main host router the EX is connected too?
- Retired_MemberApr 01, 2019
Hi, thank you for your interest.
I have reset from scratch three times.
For this work, the EX has been sitting six inches from the host.
The host router is a Spectrum Wave 2 wireless router.
Thank you!
- FURRYe38Apr 02, 2019Guru - Experienced User
Thats too close, overlap in signal is killing the EX. I would try out at a distance of 20 feet.
- Retired_MemberApr 03, 2019
Thank you.
I moved the EX6150 extender a little over 20 feet away. Then I reset the EX6150. I got the same result: Green light on the Mac, but no internet
I appreciate your help.
Any other ideas?
