Retired_Member
Mar 31, 2019EX6150/AC1200 WiFi range extender - no internet
Hello everyone,
I've been using a Netgear EX6150 for years and it worked a charm all that time until the most recent firmware update. Since then, computer - a mac - tells me the device is conn...
Apr 03, 2019Guru - Experienced User
You'll need to refer to the Mfr of the main host router for information. Maybe there is a user manual for it.
One last thing to try. Temporarily disable ALL WPA security on the main host router. Factory reset the EX and walk thru the setup wizard. It may let you know that the wirless security is disabled. Ok this. Complete the setup. Then test to see if you get anything thru the EX with no security on the wifi.
Then Re-enable WPA on the main host router. Set WPA2 and AES only.
What kind of PW are you using on the main host router? Long and complex or just something kind of simple for your need?
Retired_Member
Apr 04, 2019I appreciate your help. I have been through the issues you are driving at already.
Thank you for your help. I am going to move on to another product.
Thank you
- FURRYe38Apr 04, 2019Guru - Experienced User
Good Luck.
- Retired_MemberApr 04, 2019
Thank you
- lgkahnApr 10, 2019Aspirant
same issue here was working, then spectrum changed something... extender never had firmware update and stopped working.. tried new extender no go, updated extender to latest firmware no go.. i can connect either via wps or manually same as you lights on says connected but not really and no internet...
did you ever find a new router that works with the current spectrum wifi tower...
