Retired_Member
Mar 31, 2019EX6150/AC1200 WiFi range extender - no internet
Hello everyone,
I've been using a Netgear EX6150 for years and it worked a charm all that time until the most recent firmware update. Since then, computer - a mac - tells me the device is conn...
Retired_Member
Apr 04, 2019I appreciate your help. I have been through the issues you are driving at already.
Thank you for your help. I am going to move on to another product.
Thank you
Apr 04, 2019Guru - Experienced User
Good Luck.
- Retired_MemberApr 04, 2019
Thank you
- lgkahnApr 10, 2019Aspirant
same issue here was working, then spectrum changed something... extender never had firmware update and stopped working.. tried new extender no go, updated extender to latest firmware no go.. i can connect either via wps or manually same as you lights on says connected but not really and no internet...
did you ever find a new router that works with the current spectrum wifi tower...
- PixelWizard101Jul 13, 2019AspirantI have the same problem as well. The most infuriating part is there seems to be no correlation between the highs and lows of the extender’s accountability. It’ll work for a full day and then the next morning stop. Nothing has changed and nothing can change it. It feels like it’s a matter of pushing buttons and hoping it works out. My location is optimal and I get nothing but green from the extender’s end, but I have no internet whatsoever. To the point where the original internet network actually works better, and that’s saying something. Firmware is up to date and I’ve tried everything I can, messing with both the router, and any device I try to connect it to. Anybody have a clue how to solve this, yet?
