PQALZM
Mar 24, 2018Aspirant
EX6150/AC1200 WiFi Range Extender
Hi Just received this today and initial set-up has been very straight forward. However, ideally I'd like the extender to work by replicating the network so that devices will connect seemlessl...
jvasanth1984
Mar 24, 2018Virtuoso
Hi PQALZM,
You can change the SSID of extender to same as router. You can use the link https://kb.netgear.com/26074/How-to-change-the-SSID-password-and-wireless-security-of-your-EX7000 to do the same. Do note that not all devices will do seamless roaming and devices that supports 802.11k only support seamless roaming.
- PQALZMMar 24, 2018Aspirant
Thanks mate
