rdlc's avatar
rdlc
Initiate
May 08, 2020
EX6150/AC1200 WiFi range extender
Hello, I had to reconfigure my Netgear EX6150 AC1200 WiFi Range Extender to my new router. If I connect it to a to my router via an ethernet cable, everything works fine (I can access the setup wiza...
  • plemans's avatar
    May 08, 2020
    Are you setting it up in access point mode while connected to it?
    Make sure the switch on the side is set in extender mode during setup. So power off the device, put the switch in extender mode, and then go through setup.
    I also recommend going through setup via the wizard and not wps. You said wizard but I've assumed before.
    What router is it connected to?
    Firmware on the extender?
    version 1 or version 2?
