JMoerk
Sep 04, 2019Follower
EX6150v2 Cannot connect with WPS nor Netgear Installation Assistant
Installed and was working fine with modem with WPS button.
Got a new cable modem (Arris TG3452) from Morris Broadband (NC). Does not have WPS button, therefore cannot connect via WPS.
When I try to connect with installation assistant, the NETGEAR_EXT does not appear in the connection manager, thus I cannot connect with mywifiext.net.
Is this extender incompatible with this cable modem, or am I missing something?
Thanks
1 Reply
- Christian_RNETGEAR Employee Retired
JMoerk,
Factory reset the extender by pressing on the small black button using a pin for 15+ seconds then join the NETGEAR_EXT wifi network using a phone or laptop. After you connect to the NETGEAR_EXT network with your phone or laptop, browse to www.mywifiext.net and follow the setup instructions.
~Christian
