Swarson
Oct 14, 2024Tutor
EX6150v2-Connects to my router but can not see on WiFi choice
I bought an extender a year ago and it was working until recently. We have had several hurricanes and power outages. I updated the firmware as suggested and can connect the extender to my router with a strong signal. When I go to connect a device to the extender it is not listed. I only see my primary network. I have done multiple resets with no luck. Any suggestions? Thank you!
yes they should roam to the stronger signal but that's depending on the devices (phone, computer, gaming device) own roaming protocols.
You can leave it or you can log in and change it.
Easy check is to log into your router and look at the attached devices list. It should list the extender on there.
Or you can try logging into it with the app
The EX6150v2 is a "Mesh" extender. meaning if you updated firmware and set it up with its default configuration, it'll have the exact same ssid as your main network and won't show up different. this allows devices to roam between the 2 networks as needed.
You can always disable that option if you prefer but its half the point of a mesh extender.
- SwarsonTutor
Thank you for your reply. I used to see the _exe. So does this mean it is working and I should leave it be? My devices will roam to the stronger signal? Thanks again, just trying to understand these devices. My son does gaming and needed a stronger signal in his room. He had been connected to the _exe.
