LDC5
Oct 13, 2023Follower
EX6150v2 Extender not connecting to Xfinity Xb8
Hi, my Netgear EX6150v2 Extender will not connect to my new Xfinity Xb8 modem, that just replaced an earlier model Xfinity modem.
Oct 13, 2023Guru - Experienced User
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
