dakrath
Jun 17, 2019Tutor
EX6150v2 no longer sees 5GHz network
My EX6150v2 (firmware V1.0.1.76 )is suddenly no longer seeing my 5GHz network that I want to extend. 2.4GHz is working fine. My unit had been working fine since September 2018 without issue. I hav...
- Jun 19, 2019
channel 132 is a dfs channel. I don't believe the ex6150v2 is compatible with dfs channels. If you can get your neighbor to change it back to the higher channels, it should work fine again. Shoot for channels 149-165.
dakrath
Jun 17, 2019Tutor
Also adding that I am able to connect to my 5GHz without any issue from other devices.
Jun 19, 2019Guru - Experienced User
What channel is your main router 5ghz channels on? Have you changed those recently?
You don't list your model router or firmware on it?
Firmware on the EX6150?
I'd try changing your main routers 5ghz wifi channel. How far from your router is the extender? Size area its covering?
