tonto2144
May 08, 2020Aspirant
EX6150v2 slow speed
I have EX6150v2 connected as AP to Cox modem (Arris TG1682G, firmware TG1682COX_3.14p10s_PROD_sey) which I have download speed of 150mbs connected with ethernet and with 5G when close to the modem/ro...
- May 08, 2020
Firmware on the EX6150?
Are you testing over 2.4ghz or 5ghz?
have you tried changing the ethernet cable? Maybe move the extender next to the router and use a known 6ft cable to ensure it isn't a cable issue?
Have you tried changing the 5ghz wifi channel?
May 08, 2020Guru - Experienced User
tonto2144
I couldn't access the EX6150 to tell which firmware I had. However, I plugged it directly into the router with a different cable, I was able to get the proper download speed. Probably, the cable in my wall is bad. I was using both 2.5 and 5ghz. Thanks for the prompt reply.
