norvmark
Nov 23, 2022Aspirant
EX6150v2 will not connect to Hitron CGNM Cable Modem
I moved the EX6150v2 Extender from one location to another. Different residence, different cable modem/router. I defaulted the extender and started from base. The extender will not make a connectio...
Nov 24, 2022Guru - Experienced User
When you first setup the extender, it should pull a new ip address from the router. The 192.168.1.250 is just the default until the router assigns it an IP address.
What actual hiltron is it? (model number from the label)
norvmark
Nov 24, 2022Aspirant
I thought I put the model of the Hitron but see that I did not. It is provided by Sparklight and is the CGNM-2252 P/N 1510630024N0. The extender sees the broadcast SSID and security protocols, but will not connect. I think my problem is ether the configuration of the modem is preventing a connection or the extender is bad. I just cannot confirm which it is.
