miketram
Jul 15, 2025Aspirant
ex6170 extender
I have a ex6170 ac1200 extender and a Verizon Home Internet wifi router. I can't get the extender to connect to the router. I've followed all of the instructions and still not success. help
- Jul 16, 2025
what verizon router? Some have "son". Self organizing network. Its their version of mesh and needs to be disabled if using a 3rd party device.
What method of setup did you use?
miketram
Jul 17, 2025Aspirant
Plemans, CrimpOn,
Thanks for your advice. I've moved it to several places but the results have been the same; a marked decline in speed.
Do either of you have any experience with a powerline adapter. The reviews are generally good, but who knows if it will really work. I guess I could try it and just return it if it doesn't work.
Thank you both for your help. It did help me successfully connect the extender.
Mike
