Chongmc
Jul 16, 2019Aspirant
EX6200 AC1200 WiFi Access Point - Having problem with 2.4G band
Hi. I'm having problem on 2.4G band with my EX6200/AC1200 Dual Band Wifi Extender. I connect it with a ethenet cable, so it act as a access point now. When I speed test while connecting 2.4G, it ...
Jul 16, 2019Guru - Experienced User
You have 3 of them?
All setup in AP mode wtih a hardwired connection?
Are they using the same ssid or different ssid's? If they're they same ssid's, your device might be retaining connection to one of the other devices. 2.4ghz broadcasts further than 5ghz.
What firmware is on them?
what are they connecting back to? firmware on it? Is it using same ssid?
- ChongmcJul 16, 2019Aspirant
Hi,
Yes, all 3 are in AP mode with hardwired connection.
Yes, all SSID is the same. But I tried to disconnect the wifi (at phone or laptop), just to make sure it had connected into the correct AP (by looking at the Wifi bar, as 3 of them located quite far away from each other). I also tried to change the name of the SSID too, but the outcome is the same.
Firmware version now is: V1.0.3.88_1.1.123
This 3 Netgear extender is connected by a CISC Switch with hardwire, and this CISCO switch is connect to ASUS rounter. The think is, ASUS rounter itself have dual band Wifi, but it give no problem on both 2,4G and 5G.
Again, this problem only occur with my 2.4G, 5G is working fine.
- plemansJul 17, 2019Guru - Experienced User
so no issues with the asus 2.4ghz? does it have the same ssid?
Have you tried shutting off the other AP's (just for testing purposes) and speedtesting?
How close are these together? You're running 3 ap's plus the main router. I'm curious how much area you're trying to cover
How are you doing the speed testing? device,website, etc
Whenever I find multiple devices with the same issues, I'm less inclined to believe its an issues with the extender and more an issue with the way its setup or the device you're testing with. And they all have the same slow speed issue?
- ChongmcJul 17, 2019Aspirant
Yes, I have no issue with Asus 2.4G and yes, we are using same SSID.
There 5 floors in my building here. I having a EX6200 at ground floor 2nd floor and 4th floor. I attached a picture for better understanding.
I'm using Ookla speed test on a phone and laptop aswell.
I get like 10+/-Mbps per second when I'm standing beside the extender. But if I stand slightly away like 7 meter away, the speed will drop to 1+/-Mbps.
And no, I haven't tried shutdown other EX6200 for testing purpose.
Any advise to how should this be setup? Such as I'm not suppose to use same SSID? Channel of 2.4G all must be different (channel 1 for first device, then channel 6 for second rounter. then 11 then back 1 etc)? Any advise?
Thanks.
