PawanSaxena
Nov 11, 2021Follower
EX6200 died after firware upgrade
Model: EX6200|AC1200 WiFi Range Extender Updated fimware of EX6200 extender that was working fine. It finished but then stuck for a while. Now it won't do anything to reconnect to the router. I tri...
Nov 11, 2021Guru - Experienced User
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
