wilkjohn
Aug 07, 2020Follower
EX6200 Extender and XAVB5101 Powerline Nano, poor extender signal
I have a CISCO DPC3941T cable,wifi and voice modem rented from Xfinity. I use the Netgear EX6200 range extender but it often drops the connection. Can I use the Powerline Nanos to bring the modem con...
Aug 07, 2020Guru - Experienced User
You should be able to. You'd need to put the EX6200 in AP mode.
Have you tried moving the extender closer? Sometimes a lateral move can help more than moving closer if something in the walls is blocking.
or changing the wifi channels it broadcasts on? Maybe there's interference.
