quark
Dec 17, 2019Aspirant
EX6200 extender setup after NBN
I have had the extender working quite well for a few years without any problem. After the NBN installation, then it stopped working. So I attempted to reset the extender to connect with the new Wifi ...
Dec 26, 2019Guru - Experienced User
to reset the extender follow this procedure.
Turn on the extender and let it fully boot.
Once its booted, push and hold the reset button. It should only take 7-10 seconds but some have taken up to 30 seconds. You'll know you've held it long enough when the light on the extender change
quark
Dec 26, 2019Aspirant
I have followed your instructions to reset the extender, and then followed the Netgear instructions to setup with the Netgear genie. The setup went through as per the instructions with no problem and the extender networks mynetwork_2GEXT and mynetwork_5GEXT were set up. On the extender, the 2.4 GHZ indicator shows steady green, the device to Extender LCD also shows steady green. But when I select mynetwork_2GEXT or mynetwork_5GEXT, I still get No Internet Connection. The message on my iPhone says "if this is your Wi-Fi network, try restarting the modem and the router or contact your ISP". Is it an issue between Optus/NBN network and the extender? Should I contact Optus to get this problem resolved? Thanks.
- quarkDec 27, 2019Aspirant
Also how do I find out the firmware version on my extender and update it if necessary? Thanks.
- plemansDec 27, 2019Guru - Experienced User
The firmware is usually listed on the status page of the extender when you're logged into it.
Potentially your optus router is causing the issue. maybe you need to set a static address for the extender for it to work properly.
