dk2463123
Oct 15, 2015Aspirant
EX6200 loses connection to primary router on Windows 10
Have the EX6200 set as an extender via WiFi then using ethernet connection to my PC. When I cold boot the PC, the 2.4Ghz link and the Device connection lights are green. Once the PC boots, the connec...
nhann
Oct 16, 2015NETGEAR Employee Retired
Hi dk2463123,
Which router are you using with the EX6200?
Please see:
You can also contact support and provide them with your EX6200's config file to help them troubleshoot your issue.
http://support.netgear.com/general/contact/default.aspx
